Ihave a temp. of 85.5. The dew point is 75, heat index is 94.6 , humidex is 106 and the conditionscolour.jpg is saying its warm. Does the conditionscolour.jpg only based on temp. or should the humidity have a factor in the jpg? It certainly feels more than warm.
its based on the humidex
maybe i should make the thresholds user setable :wink:
Mine always goes from comfortable to warm when the temp gets to 80 degrees. Humidity doesn’t make a difference that I can see. User selectable would ge great.
If it wouldn’t be much trouble, Brian, to be able to tamper with the settings would be a nice touch, Could you also add a default option in case the settings are a tad off when the user sets them. Kind of like what you have for the weather conditions.
So, you might have hot, or if you are in the Bible Belt of America… one could say…"You think this is hot? wait until you end up in the here - after.
:twisted:
uploading 10.16a now
where you can twiddle with the thresholds
see in the summary image and icon setup…button to get to the setup screen…
also fixed a bug with the high temperatures…
that is super, I can really follow up things now. Its been way, way too quiet lately.
Say, Brian, will this update that Windows have any issues with WDisplay? The only thing Ihave heard there is a lot to do with security issues and we have an option of declining MS firewall and use what we are doing instead. So I am guessing the only issues will be permisssion via the firewall and they are solvable.
I don’t know about the OS , but I am assuming that I will be visited by the Update fairy soon. :roll:
I don't know about the OS , but I am assuming that I will be visited by the Update fairy soon. :roll:
I would wait for a little bit http://www.eweek.com/print_article/0,1761,a=133711,00.asp :P
WOuld you buy a used car from Microsoft? not a chance
