Brian:
Is there any possibility of offering the possibility of changing the language of the conditions?
Thanks and cheers
H
Brian:
Thanks and cheers
H
ok, yes, i can add to the language.ini file
i will see about that today, all going well
yes I noticed this suddenly is generated now along with other webfiles. What is it for exactly? it doesn’t get FTP’ed though - which screen in WD gets it to upload?
cheers
it should get uploaded when the gizmo is uploaded,if that is set to upload…
ah ok - I don’t upload any gizmos - ta for the info
i have added the ability to change the language, wording
using the language.ini file , in a new 10.15, uploading now (will be ready in an hour or less)
(have a file called language.ini where you have WD installed , and have this in it (i.e put the words you want after the =)
[Current conditions image]
extreme cold=
uncomfortably cold=
cool=
comfortable=
warm=
Uncomfortably Hot=
Extremely hot=
Caution=
Danger=
Extreme danger=
Thanks again, Brian.
Cheers
H
perhaps one or two others - Cold as Hell and Repent, where you are going is hotter?
:lol:
Ok. I’ll be quiet.
Actually, these are great to have on board.
i have added the ability to change the language, wording using the language.ini file , in a new 10.15, uploading now (will be ready in an hour or less) (have a file called language.ini where you have WD installed , and have this in it (i.e put the words you want after the =) [Current conditions image] extreme cold= uncomfortably cold= cool= comfortable= warm= Uncomfortably Hot= Extremely hot= Caution= Danger= Extreme danger=
out of curiosity - what are the temperature ranges/colours for these conditions? should there be caution and danger set for the cold end of the scale too perhaps?
Martyn wrote: “out of curiosity - what are the temperature ranges/colours for these conditions? should there be caution and danger set for the cold end of the scale too perhaps?”
I think this can help: Latest World & National News & Headlines - USATODAY.com
Cheers
H
