I have added more wind debug info
download from the normal download this time, the update
I’ve downloaded the file consolewd64.tar.gz (Version on 17 January 2018 - 03:20:04) and placed all of the files but I’m still getting the gust and speed mirroring.
I’m piping it into a text file again and will update this thread.
EDIT
Updated output from running the new version of consolewd.
http://digitalessence.net/weather/console-output.txt
Interesting. The data uploaded to Wunderground is showing a different value for windspeedmph &windgustmph. see this excerpt: We don’t have much wind today so I don’t have much data to go on but I will monitor it and report back.
data read length ->15
01 FF FF 00 42 C1 01 00 62 00 00 00 20 86 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01 FF FF 00 42 C1 01 00 62 00 00 00 20 86 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 FF FF 00 42 C1 01 00 62 00 00 00 20 86 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
temperature found, sensor # 0
Temperature data found
send PC ready result 1
Current data 08:44:49: Temperature= 0.1 Windspeed =0.0 Gustspeed =0.0 Direction =135 Humidity=98 Barometer=991.0 Daily Rain=0.0
data read length ->-1
**** doing minute rWU data to send http://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=ISCOTTIS5&PASSWORD=XXXXXXXXX&dateutc=2018-01-17+08%3A48%3A00&winddir=111&windspeedmph=1&windgustmph=3&humidity=98&tempf=32.1&rainin=0.00&baromin=29.264&dewptf=31.6&weather=&clouds=&dailyrainin=0.00&solarradiation=0.0&UV=0.0&softwaretype=WeatherDisplay%3AWD_console_14.0&action=updateraw
Wunderground data send Ok 08:45:01
regards,
Hedley
that link does not work?
wind found
speed= 0.9 m/s dir 135 average 0.9
that shows that for the raw data, the 2 values are the same
for wunderground data though, it will be sending an average of the average speed values (and then maximum of the current speed values since last data send), sort of thing
Ok.
So in WD, the Windspeed and Gustspeed will always be the same value?
not normally for other station types
but this station type they are being provided as the same number
(I could then make it so that there is a running average for the average speed)
The WMR180 only transmits a wind value about each minute, so there’s no real current/gust data.
Ah ok thanks.
So, I think everything is working correctly and I now have my WMR180 connected to my Raspberry Pi 3 feeding into Wunderground and you don’t know how happy this makes me.
Thank you ever so much for all your hard work, coding and testing while I’ve sat for 4 pages on this forum going “nope, doesn’t work”.
EDIT:
I switched from my install provided by mihec which is a console only distro to the Raspbian one provided on the Raspberry Pi website.
I followed the install instructions and oddly the barometer never changed from the default 1013.0 even though I left it all day.
Powered down and restarted the one provided by mihec and within 10 minutes it had picked up the correct barometer reading. This is odd as the other settings were all correct and as expected.
My install procedure is as follows:
1.1 modify /etc/apt/sources.list
sudo pico /etc/apt/sources.list
Add one line to that file, remember to use sudo or use the gui in a root file-manager window
deb http://ftp.nl.debian.org/debian/pool/main/u/udev/libudev-dev_175-7.2_armhf.deb sid main
execute in a terminal window
sudo apt-get install libudev-dev
sudo apt-get install libusb-dev
1.2 install libhid
1.2.1 download from http://alioth.debian.org/frs/?group_id=30451.
1.2.2 modify in the downloaded folder libhid/test/lshid.c line 41
Reads now:
len = ((unsigned long)custom);
modify that one line and add the extra two lines:
//len = ((unsigned long)custom);
len = len;
custom = custom;
1.2.3 When you are in that folder in a terminal window
sudo ./configure && make
Or if you get errors:
sh configure && make
At the end you will may get an error 2 in the make part, ignore that
sudo make install
This finishes without errors
Second step, install and test consolewd
2.1 download from http://www.weather-display.com/downloadfiles/consolewdfilespi.zip
2.2 unzip the folder
2.3 modify the text file config.txt in the unzipped folder with your settings
2.4 Copy the consolewdfiles folder to your pi folder on the RaspberryPI
2.5 Set all rights of the consolewdfiles folder to 777 including all of its its contents
chmod 777 -R consolewd/*
2.6 copy all files from the consolewdfiles/deploy to the systemfolders
Copy libhid.so.0.0 to libhid.so.0
to stop error when running consolewd
cp libhid.so.0.0 libhid.so.0
Then copy all the files.
sudo cp . /usr/lib
sudo cp . /usr/local/lib
Reboot.
sudo ./consolewd
