Com port (2)
Hi W.D cannot recognize the com port. it did b4 though. is this because i have Zone Alarm runnin?
I run ZA so I don’t think that can be it. If you set it to a different com port, eg 2 if you are using 1, and then reset it to 1 does it work? I (and I believe a few others) had that problem show up a while ago and have never found the answer. Finally I changed the station to a different port and it’s been fine ever since.
the fact it was going, but now doesnt, means something has changed
try exiting wd, then delete the wdisplay.ini from c:\winnt or c:\windows
then restart wd
and then it will be like brand new, and so then you can reset up the com port and weather station type. etc
but, also, what does it say across the top of the program?
also, too, try another weather station software and see if that works
but, make sure no other software is using the com port at the same time
