Is there an easy way to add colour to a post? I did it today using [color=red] / [/color]
, but it was a bit of a chore. . .
I’ve added something that might make your life easier. There’s now a palette button on the composer toolbar.
Select some text that you want to colour, then click the palette button. It will add a ‘wrapper’ around the text, e.g.
You can then change ‘color’ or ‘bgcolor’, or both, to change the text colour or background colour. If you leave either of them as ‘#’ then it takes the current default colour, i.e. white background or black text. That’s to avoid you needing to delete the unwanted part of the wrapper.
Some examples:
Red text on a yellow background
Green text on the default background (white)
Default text (black) on a cyan background
Red text then turning on yellow background before finishing back on red text
Default black text on a yellow background turning to red text on a white background before finishing back on default text on the yellow background
The last two were done by embedding a wrapper inside a wrapper. The outer one has yellow background set with default text. The inner wrapper has white background and red text colour.
If the wrapper is at the end of a line then it colours to the end of the line, e.g. the examples above. If the wrapper is embedded in a line of text then it just colours the part of the line it’s embedded into, e.g. this sentence.
Finally, The colours can either be RGB Hex, e.g. #00FF00 (green), or you can use any of the 140 (?) HTML colour names, e.g.
Some text in RebeccaPurple on a LightGoldenrodYellow background
You can now show off your artistic talents with all sorts of unusual combinations!
Thanks. A button on the toolbar was exactly what I was looking for
