cloud base in meters
I have WD set up to display metric values of all fields. When I click on the weather icon image to display the metar data everything appears in appropriate metric units except the cloud base field - it shows up in feet.
If metric is selected as an option, can we also have cloudbase displayed in meters?
WD already has that option.
Go to: Setup…then to: Display unit options/reset times/altitude/and other settings. See if you have the box checked that says: “Show cloud height in meters” (it’s down towards the bottom right) I tried it out on mine and it did the trick! :slight_smile:
Thank you very much!
