I developed a problem over the weekend where the program will just shut down few minutes after I start it. I have tried rebooting the computer,and it still will close, I have made no changes in the program before this started. Sunday I did an update to 112 in hopes that would fix it but it still just closes after running for a few minutes.
is WD getting data OK from your weather station?
do you maybe have set to use and run WDwatchdog?
what weather station type?
Yes it is getting the data, did not have WDwatchdog tagged but do now and it is a Acurite 5-1 Pro
I did not mean for you to have watchdog running
I was just asking if you did
when this problem started, what changed?
I do not know of any change. When I went to bed it was working when I got up Saturday it was crashing every few minutes. I made no change to the program. There was no update to windows either
do you have WD set to do any internet updates?
try turning those off as a test
do you have it set to use an images?
does it crash at a certain time? (minute)
I have turned off all internet updates and uploads now. I do not upload images. It seems to crash every 5 minutes which is the time I do uploads to the internet
did you turn off the main internet switch?
it sounds like something is corrupted
if you could email me your settings files then I can test/check here
Yes I did turn off the main, and it worked just fine for several hours. Then I turned off every switch I had on in the internet file creations and uploads, and then started turning them back on one by one. It started to crash just recently again so I am going to start the process in reverse to see if I can narrow down the one that may be crashing it. If all else fails I will email my setup. Being under stay at home orders this at least gives me something to pass the time with.
