Clientrawrealtimeftp.exe not starting automatically any more [RESOLVED]
I’m currently running the latest build 57, but several builds back I noticed that the clientrawrealtimeftp.exe program stopped starting automatically when WD started. Up until then, it worked.
Now I have to go to Control Panel->Web Files/Web Page/Real Time FTP/WDL page and click the “Start now” button on the Real Time Client FTP/AJAX/WDL Setup tab to get it to run.
Did I mess up a setting or something, or is this a new bug?
Thanks!
no problems here, build 57
how long are you waiting for it to start up?
Once, I waited 18+ hours (forgot to start it manually). How long should it take? It used to start within a few minutes before it stopped working.
What setting causes it to start? Maybe I turned it off? BTW, it works fine once I manually start it.
should be after a few minutes
do you have the main internet switch on in the ftp/internet setup,connections setup and have ticked there to use weather displays Ftpupd.exe? (default is on)
Yes, all those are set as you say. I didn’t change any settings when updating from build to build (I update each time a new build is put on the website). It just stopped starting automatically maybe 5-10 builds ago. But, like I say, once I start it manually, it works fine.
.zip and email me your settings and I will test/check here
OK. What file(s) do I include? Just wdisplay.ini?
We have a FAQ for that http://discourse.weather-watch.com/t/12684
you have ticked, I am running my own server, no ftp needed
in the webfiles/web page setup, real time ftp
that should not be ticked
untick that
That did the trick! :smiley:
I don’t know how on earth that got ticked.
Thanks so much for your help and patience.
