Clientrawextra
Any idea why “clientrawextra” not updating every time? This happen many times / day.
This cause “zero values” on WDL 24hrs graph.
Below is two files. First is “zero file” and last is ok.
WD is 10.19t (24.Nov)
Os. WXP Pro SP2
FIRST;
12345 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 9.5 11 58 05 11 2004 -11.9 06 49 22 11 2004 23.5 08 30 12 11 2004 0.0 00 00 01 11 2004 982.6 13 29 18 11 2004 1027.2 11 29 24 11 2004 28.0 23 59 12 11 2004 4.0 09 21 13 11 2004 13.0 13 45 12 11 2004 0.0 00 00 00 00 00 -50.0 15 57 24 08 2004 100.0 15 57 24 08 2004 -13.6 23 34 21 11 2004 281.0 00 00 00 00 00 193.0 00 00 00 00 00 8.1 18 00 05 11 2004 -9.3 06 59 20 11 2004 -7.6 18 00 24 11 2004 6.8 06 00 12 11 2004 9.5 11 58 05 11 2004 50.0 11 48 09 07 2004 30.2 14 32 05 08 2004 -20.9 08 40 23 01 2004 23.5 08 30 12 11 2004 80.3 13 48 14 09 2004 975.3 13 00 21 03 2004 1043.6 11 00 10 03 2004 42.2 20 26 17 08 2004 25.5 15 47 17 08 2004 13.0 13 45 12 11 2004 0.0 00 00 00 00 00 -2.2 15 57 24 08 2004 -2.2 15 57 24 08 2004 -26.0 18 40 28 01 2004 281.0 00 00 00 00 00 193.0 00 00 00 00 00 24.7 18 03 04 08 2004 -9.3 06 59 20 11 2004 -7.6 18 00 24 11 2004 20.7 06 00 08 08 2004 31.1 12 25 05 08 2004 50.0 11 48 09 07 2004 30.2 14 32 05 08 2004 -20.9 08 40 23 01 2004 23.5 08 30 12 11 2004 80.3 13 48 14 09 2004 975.3 13 00 21 03 2004 1043.6 11 00 10 03 2004 42.2 20 26 17 08 2004 25.5 15 47 17 08 2004 13.0 13 45 12 11 2004 0.0 00 00 00 00 00 -2.2 15 57 24 08 2004 -2.2 15 57 24 08 2004 -26.0 18 40 28 01 2004 281.0 00 00 00 00 00 193.0 00 00 00 00 00 24.7 18 03 04 08 2004 -9.3 06 59 20 11 2004 -7.6 18 00 24 11 2004 20.7 06 00 08 08 2004 31.1 12 25 05 08 2004 50.0 11 48 09 07 2004 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 20:35 21:50 23:02 00:14 01:26 02:38 03:50 05:02 06:14 07:29 08:41 09:53 11:05 12:17 13:29 14:41 15:53 17:06 18:18 19:30 0 6.0 6.0 1 0 0 0 0 0 0 0 0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 pilvistyv
this might be from your exception error you are getting (from the thread)?
maybe you have some data that WD does not like…
(maybe zip and email me your datafiles)
or some other setting or similar that is cuasing that error (and then that error stops things from being done correctly)
