Hello
My clientrawdaily.txt got stuck. For the last four days it has a flat line.
The 24 hour is working OK but the 7 day and 31 day graphs in WDL is not so good.
UPDATE
The 7 day graph is now OK, showing yesterdays values but still monthly graph is 4 days behind.
I waited out a new month in hope that it should be “corrected” by itself but to my dissapointment i did not.
Yeaterdays rain happened 4 days ago in monthly graph and the last four days is flat.
any errors in WD under view, program event log?
also what is the barometer reading in WD?
also which version/build of WD? (that info should always be provided)
Hello
Barometer reading is OK
Right now 984hPa
The message in Eventlog
Not enough storage is available to process this command.
error with loading weather dials customisation
ERROR: Not enough storage is available to process this command.
at time/date 20:45 08-12-11
Cannot create file “D:\web\Vader\wd\forecast5day.gif”. The process cannot access the file because it is being used by another process
