Since I don’t know when, WD stopped producing the clientraw.txt file. I allready tried everything. I don’t need to ftp the file, as my computer runs as a server for some time, but I suspect this began happening exactly after that change. Can you help me?
what i would do:
go to setup, control panel, webfiles/web page
then in the real time ftp setup, make sure you have that enabled to produce and upload the clientraw.txt, but tick, no ftp needed
then in the ftp/internet setup, client/server setup, you will need to set that location for the clientraw.txt file , to be where your web files are location on the your pc for internet access
Yes, I did all that, even if under client/server setup I didn’t tick, for a first time, to set the location for the file. Then, I ticked to use the file and ticked also to set the location, even if it says not to do it if WD is connected to a weather station. The truth is nothing happends, one way or another…
File deleted, no new file added. By the way, I don’t know if this is important or not, but I changed the webfiles folder for a new one, when I changed my computer to be a server…
Yes, I mean… I ticked where it says “Use the clientraw.txt…”, I also clicked where it says “Set location for…”, tried with both, tried with the two separatly…
