krelvinaz (Kevin) has kindly made his clientraw file parser available again for us all to use. The parser is an excellent way to see the data held in the various clienraw files produced by Weather Display. Kevin tries very hard to keep the parser up to date with all the change that Brian makes to the file from WD.
WD Clientraw parser has been updated to reflect the changes in Weather-Display 10.29i
Other changes:
Added calculation for the Lettered Wind Direction (used to just show Degrees)
Added a calculation on the Cloud Height, which WD shows as FT so that it shows Meters and Feet.
