Clearing WD of all data-starting anew
How is the proper way to clear wd’s old data and or histories? Mine is corrupted.
I do not wish to remove the program settings. Just the logs and databases as they do not give proper reports or displays.
there are in the logfiles and datafiles folders
but there is also data in the wdsiplay.ini file
delete sections in there that are not related to colour setup, weather station type
i.e all time records, wind run, etc
but bnad data can be edit out
i,.e for the log files, you can edit it out, and in the wdisplay.ini file you can edit it out…
Thank you. Keep up the good work
