Changing the scale
I Brian,
one question: how can I change the scale on the main graph temperature (I
[quote author=barcello link=topic=6187.msg40782#msg40782 date=1100300285]
I Brian,
I tried but nothing happened, can you give me more details?
Thank
Yes, I have the same situation. No matter what I put, it is “stuck” at 60 (knots) on my main graph. What are we missing?
humm
if the wind has gone over 25 knots in the graphing period, then the graph max scale will auto scale to 2x that, i.e 50 knots (or what ever your units are)
I will do some testing/checking of the set max windscale, maybe I have a bug there!
(it should be an override, yes)
not working here either…
Hmmm, I remember when it used to do that. Mine has been “frozen” on 60 for many many versions along the way. Thanks for taking a look at that. :slight_smile:
Same here…
When I checked e.g “temperature range 10” It works in main graphs. But when I restart WD it’s again default 40.
And 24/48/72 hr graphs are always “default range”.
Here is a lot other “unsaved” options.
Eki
the auto scaling of 0 to 25 changing to 0 to 50 (knots) works OK for me
one person, where this is not working, email me your datafile, latest.inf
and the data file month12204.inf, and your settings file, wdisplay.ini, from c:\windows or c:\wint
and i will see what is wrong, and I will also look into the setting max scale
also, i have fixed the error with the temperature scale not being remembered
will be ok for the next update
note, for the max wind scale to work, you need to have ticked, plot the windspeed only half scale toggle, ticked (near the top of the graph setup)
and that will get the auto scale to work good too (that is how I have mine setup)
but i will make the set max scale to work regardless
i have wmayo’ data and setting
and this now works as it should in 10.20L
