Changing high temperatures. how?
What is the easist way to change high temeperatures. I need to lower the high temps that are showing up in my NOAA report for a three day period…when i had my temp probe moved to a different location which didn’t work out (recording a few degrees to high)…
you could try:
edit the logfile, 92004lg.tx, and lower the temperatures number…for the highest readings…maybe
that is what I figured… I was just hoping there would be an easier way… :cry:
