Change the scale on thermometers
I don’t think there is a way for the user to do this. I read the config doc and I don’t see a way.
Currently the length of the scale for the thermometer is 90 degrees F (14 to 104). That’s quite a wide range. The last few days the range of temps locally has been 10 degrees. With that swing it’s sort of lost in the middle of the 90 degree span.
It would be nice if the control (guage) would have more limited range and size according to the daily range.
See Temperature scale
Julian
i think its the range of the scale…(i.e the low and high value of the scale difference)
that maybe could be set to be less (maybe customise?)
Not easily…
Julian
I have tried the scale settings with the free client viewer with no success.
Frank
there is only a setting in the free client viewer to set the graph hi/lo range
i would need to add ability to set the temperature gauges hi/lo range
but, the temperature gauges from value should auto adjust as the temperature gets colder
what temperature frank?
In the client viewer I set the temp to 20 Low and 80 High but the graph labels show 0 to 120
Frank
