Change the max temperature extra temp 1
.(Translate)
Hello
I’m looking for how to change the max temperature extra temp 1. Can you help me.
Thank you.
Serge
I am not sure if you can change it (i.e. set it) in WD, but you can reset it - whatever that means - in Action > Reset/Set Daily Extreme Values/Storm Rain.
Thank you for your ‘bitsostring’.
I searched and couldn’t find a solution. I think that is a shame.
Serge
when you say change what do you mean the name???
(Translate)
Hello
I would like to change the following temperature in extra temp 1: 6.2°C by 6.9°C I can’t figure out how to do it?
Thank you.
Serge
in WD there is an option for temp offset. Go to Control panel > Offsets, here you can change the temp up or down how much you want. Is this what you require?
From the topic title and the first post I got the impression that it was a single rogue value of max extra temp 1 that OP wanted to change. I can’t think of a way to do that.
Indeed, that’s what it’s all about.
