Change the link of "Home" - What about ! DW
Hello
Left of the index, there is menu and link home.(https://www.meteoacharnes.ελ/pwsWD/index.php)
How and in which .php i can change the link of home to https://www.meteoacharnes.gr?
Also, in the end of the page there is ! DWL. I open it and i see that some elements, has delay. Is it normal? Because for let say https://api.waqi.info/feed/geo the delay is more than 40 min and if i go to https://api.waqi.info/feed/geo i see {“status”:“error”,“data”:“Unknown station”}
Regards
Vaggelis
The home points to the start of the dashboard.
That button is “used” for instance when you select an item from the menu.
See attached screenshot.
I do not think that visitors understand it when they,
=> after selecting a menu item, have read that page
==> and want to go back so they click the “Home” button.
=== > and then go to another website
Also, in the end of the page there is ! DWL. I open it and i see that some elements, has delay. Is it normal? Because for let say https://api.waqi.info/feed/geo the delay is more than 40 min and if i go to https://api.waqi.info/feed/geo i see {"status":"error","data":"Unknown station"} Regards Vaggelis
That ! means there are outdated files. It is a “subtle” message to you, the owner of the site to check if there are outdated files.
If the mark is also red, there are essential files which are “old”.
During testing and installing there are often files which are no longer used.
You can remove the _my_settings/status.arr and it will be rebuild with only the used files.
If you are not running the cron-job or if you do not want that “outdated” indicator, you can change it on the last tab of easyweathersetup => Show warning mark for outdated history a.s.o.
If you want the visitors give a link to your main website, you should edit a small piece of code _my_settings/before.txt
That code is read and executed before the dashboard and ofgten contains links to other websites, or a message about whatever you want to tell the visitors.
There is also a block which is executed after the dashboard _my_settings/hooks.txt which is often used to add items such as visitors counters
Thank you very much.
Also i am running cron-job. I delete status.arr, recreated and everythins looks good.
Thank you again.
Regards
Vaggelis.
