Change Hi-Lo Temp Values
On starting WD from a complete shut down WD access the data from the data logger. When the values are displayed on WDL some are wrong. Namily the hi-lo temp values. I know these are coming from a file in WD however, after viewing all the client*.txt files the values are not present.
Question. Where are the values for the hi-lo temp coming from? I would like to correct them.
TIA,
Scott
Are you viewing your client txt files locally or from the webserver/internet? If the client files on the internet are correct and WDL is still wrong try refreshing your web browser as it may just be old values in a cache, although that really shouldn’t happen.
Julian
is that the hi/lo just for today you mean?
Yes, it is just the values for today.
I switched over to WD and allowed it to read the data logger. Which it did. When it displayed the data it’s wrong for today. That data is being fed to WDL so the values are displayed wrong.
The problem is I cannot find the wrong value (69.4) in the clientrawextra.txt file (or the others for that matter). Also. I cannot resolve the clientrawextra data line with the description file.
Have a look http://home.earthlink.net/~swest47/
The high today was 66.4 @ 13:35. The low 57.6 @ 17:47.
Also WD keeps dumping my yearly/monthly/daily rain totals.
Scott
email me your settings again, as things might still not be correct
(go action, back up registry entry now, and email me the files wdisplay.ini and wdisplayftp.reg)
also, under action, reset daily extremes, you can reset the daily max/min there
