Cellphone/Mobile Scripts (XHTML Mobile 2.3 Certified)!
I put the old css file in place and there was no change. I think the silly cell.php?skip=1 was doing something more than just being silly.
hmm… lemme look in a bit at that…
Thanks for sharing the changes you made to the mobile script. Maybe I’m missing something as I can’t seem to find the background image. I have a black background with black text. http://www.harpersferry-weather.com/cell.php
John
you can get it here…
Thanks! Another issue I have is since I don’t have a UV sensor I set $haveUV = false; The results is it’s giving me the high UV reading today of 0 when it should show the UV fcst over the next 3 days.
John
hmm something in the logic then, with that ok… lemme look at that and see if i can fig out forever’s issue also
tstorm – you need to edit the forecast-sumary file to pull in your regional nws or forecast to get the synopsis… you are still getting mine. (use LWX) you will get a nice synopsis for your area…
and the link in the footer.php to reflect your webpage.
forever can you view the source on the “wide” version? curios on the doctype. That was also before i did the major switch to WAP XHTML compliant…
I looked at the old code and all the skip=1 did was just a redirect… so it must be with the android interpretation of the DOCTYPE…
Before it was either:
echo ‘’;
else
echo ‘’;
now its
So i wonder if that is causing the android browser to behave differently with the stylesheets…
regardless you can just edit your css sheet and cell-top and change $pagewidth to like 1000…
tstorm ok check this out now and let me know… if you think its ok, ill update the main zip file…
the logic was absolute hell to get the formatting for all 8 cases… I think i got it tho… The issue was there was a 2nd line of text if you had a UV sensor and it was night… And since mobile XHTML does not allow nested tables, the logic for the formatting of the lines around the cells was difficult.
Glad you caught it tho!.. this has been a great project…
The new cell-ajax-dashboard.php fixed the problem with the UV forecast not showing at night. Thank you much!
John
John -
Glad that fixed the problem… You dont need the cell.php?skip=1 anymore… you can change your xml file…
I think you are using the older cell-radar.php and cell-advisories.php files… Take a look and swap out the width=“315” to width=“<?php echo($pagewidth-5) ?>” on all the image links. That dynamically changes the width to just be a bit smaller than the page width…
Updated “a” zip to include the fixed cell-ajax-dashboard.php.
Starting to see a few people use these – glad they are helpful to others!
Updated all pages with the width. Not sure which file you are talking about with the skip=1 as I haven’t found any that contain it anymore.
John
John – Your homepage
http://www.harpersferry-weather.com/cell.php?skip=1 … which is from menubar.xml
Thanks again. It was in my flyout-menu.xml .
John
yes sorry my bad… flyout-menu.xml. I knew it was some xml file lol…
OK fixed some issues that prevented the page from not displaying correctly on iphones… Had to a add a line to cell-top… Also fixed some formatting issues to make other pages look cleaner – thanks tstorm for all the help debugging this on iphones!!
main “a” zip updated with new files…
Sorry for all fast changes, but its getting pretty stable now I hope… :slight_smile:
Well, finally it’s up and running! :smiley:
http://www.meteothes.gr/cell.php?lang=en
Thanos
Looks good atsio! Your webcam tags still have the “alt” ref to my website but its not a huge deal…
Fixed! :wink:
Thanos
I downloaded your updated scripts again but cannot figure out how to change to FWI :?
Thanks for the hard work on this mobile script.
for FWI just set $fire = false; in cell-ajax-dashboard.php.
Also make sure your graphics are CBI-FireXX.gif. You can use whatever graphics you want, but for now the need to be named CBI-FireXX.gif where XX is 0,16,25,31,32.
