The forecast discussion paragraph (nice feature) is printing subsequent lines with no initial capitilization; Can this be changed? Also can "this discussion continues at www.642weather.com " be made an href in the $reports from section? I can’t figure out a proper syntax.
I was not able to make the url a href because it will not print well. The css has a feature to show full url’s when printing and it just looks bad if you add the href.
Version: 1.01 - 07-Feb-2009 added feature to uppercase first word of every sentance on the forecast discussion text
That did the trick. I should have noticed that. It was like that when I downloaded it without the echo variable. Maybe Mike needs to be aware if the fix.
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /homepages/26/d195194739/htdocs/Burgus/wxflyer.php:6) in /homepages/26/d195194739/htdocs/Burgus/include-style-switcher.php on line 29
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /homepages/26/d195194739/htdocs/Burgus/wxflyer.php:6) in /homepages/26/d195194739/htdocs/Burgus/include-style-switcher.php on line 29
Warning: Cannot modify header information - headers already sent by (output started at /homepages/26/d195194739/htdocs/Burgus/wxflyer.php:6) in /homepages/26/d195194739/htdocs/Burgus/include-style-switcher.php on line 359
Is this what you normaly get with the weather discussion
08z msas sfc analysis places high pressure over the oh vly. Warm front extends near the i-70 corridor across mo with 20+ degree temp gradient across the frontal zone. Strong southerly 40-50 kt winds in h925-h85 layer drawing gulf moisture rapidly north with sfc dewpts in the 50s as far north as central ks through southern mo with 60s from ok and tx into la. Water vapor shows vigorous negative tilt shortwave ejecting from the great basin through the rockies. Zone of strong upper diffluence and positive vorticity advection in combination with dry slot impinging on gulf moisture fueling fine line of convection from south central ks through central tx. Addition elevated bands of convection were forming out ahead from plains into upper midwest ... This discussion continues at www.burgus.org
Hey Mark, yes that looks about right. There is a forecast discussion script that you can setup as a separate page. Look on my front page, then click on “the discussion is continued here” towards the bottom of my page.
