I use XAMPP suite to test my site off line, and after version 1.7.1 (1.7.2 and 1.7.3) I get some errors or warnings
in ajax-dashboard.php. Version 1.7.1 is ok.
The errors are like: “Deprecated: Function split()”.
I think that there is an issue with the PHP version. Is there a way to suppress or even eliminate those errors?
Hi, i had the same issue with my recordspage. I changed the code “split ()” to explode() and that did the trick with me, you have to search a little bit in your pages but this resolved the error on my site. Fault is produced by a new update of PHP wich no longer supports the split() function.
[quote author=saratogaWX link=topic=32785.msg265405#msg265405 date=1214872103]
This is the initial release of the WD-World-ML template set that many have helped build. I’d like to specially thank the translators for their excellent efforts to provide the lookup tables for the translations!
