I was having major network problems (solar photodiode apparently got water in it and shorted out my whole 1-wire network). I got the whole network working and then tried to hook up an AAG barometer I have never been able to get to work consistently. MISTAKE. Now WD locks up or at least it quits reading data from the network (timer on the main page stops). I disconnected the baro from the network and then went into barometer setup and “unticked” the barometer, but it still locks up like WD is waiting for data input (I can still access the program and go to setup, view etc. but the timer/counter has stopped and I get no new readings). Rebooted and restarted computer- didn’t help. On WD start up, the sensors read, update and display properly, but about 12 to 70 seconds after the main page shows up, an old baro reading and label both pop up on the main page (the label is not present on start up- blank background).
At the same time the baro reading and label pop up the local sky icon from the local airport pops up in the icon window. So I’m not sure whether the metar or the baro is causing the problem or both. Of course the since the baro part of the program should be shut off, I shouldn’t be getting a “barometer label” on the main screen anyway. I was running 10.20i but just loaded 10.20t just to see if that would clear the lock-up. Both versions exhibit the same problem exactly so no help there. Sad and wet in Montana (it’s been raining a little, 32 F so far, getting colder). Mick
