Can WD be installed on a hosted website?
There is a message thread from about a year ago where a user was reading data from FINDU and his IP was blocked due to “inappropriate use of the FINDU system & bandwidth” (or similar…I did not go back and get the specific reason). Windy was working with this guy and actually developed a version which read from FINDU…then when the rhubarb started the function was removed, so…no, you will NOT see that functionality in today’s version…or so I understand from that thread.
If you’re interested, take a look at the following:
APRS Data from Ultimeter 2100 (Raw Format Posted to findu.com) - this thread discussing the development of that feature
WD direct connect to APRS Server (stationless setup) - this thread discusses alternatives since FINDU was removed
Anyway…it sounds like the answer to my REAL question is…“No”, can’t run WD in a hosted environment?
