Can not use any of the menu items?
Just downloaded the o version and I can not select Exit, Setup, Action, etc using the mouse. Anyone else seeing this?
More info. When I’m editing a custom screen and and have the list of custom tags listed and then WD does an FTP update this is when I loose all menu control. I have to select X to kill WD and start the program over.
Another problem I’m running into is while creating custom screens WD sometimes just exits totally.
if you have the custom screen 5 set to do internet updating, I have just found a bug there
uploading a fix for that
Yes, happened here after editing custom screens. Had to use task manager to completely kill WD.
