Can not see Advanced Settings File Create window
Hello, new user of Weather Display here!
I have the following problem and hope someone can help me.
  1. I started configuration WD on a PC with two monitors and I had the setup windows on both screens
  2. Then I moved the software to my home server that one has one monitor
  3. The software runs fine so the actual move from one PC to the other one works fine
  4. Now I’m trying to open the following window:
    “Customise Internet and File Creation Setup” → “Setup Page #1
    The I’m trying to access the “Set” for one of the files for the “Time to create the file” window
Result: I can not see this setup window, and it totally locks up the software. I need to close the process from Task Manager in order to access WD again.
My guess is that the windows is off screen somewhere.
How do I reset the windows position of “Time to create the file” window?
/Lars
I had a quick look in wdisplay.ini for the screen position of this window, but couldn’t see it. Maybe you should ask Brian, the author, direct.
Start at setup/advance/misc settings then Programs then on right side half way down start up commands check the first box start in center of screen and check OK then restart program.
I think that’s for WD main screen?
Alt+Spacebar+M then left and right arrow keys to find window and move on screen.
Or shift+right click icon on taskbar, slect move and then left and right arrows.
Jim
Thanks for answer. Unfortunately non of the above works.
I also got this error once and then the program crashed:
Got a solution from Brian:
  1. Open reg edit
  2. Search for “wdisplayftp.ini”
  3. Find the key [time selection]
  4. Remove/delete last x and last y
Now the setting window is reset and can be seen again.
