Calibration of the graph
Just a quick question regarding making my graphs look nicer. If you look at the following …
http://limaweather.com/data/curr24hourgraph.gif
… you’ll note that the bottom graph is “crunched” with data above the line. Where in the program can I set up the parameters so my readings are going to appear in the upper 2/3rds.
Fred in Lima OH
the latest version of WD fixes issues like that
otherwise try the lift/lower for temperature under view, graph setup, or under graph setup, top menu, in that older version
which version of wd are you using?
Windy,
My program is v9.89. I assume there is an update out. Any problems I might encounter in performing the upgrade?
yep, the update is here http://www.weather-display.com/downloads.php?file=wdisplay32.exe
there should be no issue when upgrading, just make sure you shut down WD first :smiley:
yes, there are updates out every day
http://www.weather-display.com/download.php
unless i am away, which is this weekend
:wink:
