Is the a bug in in temperature last hour.
The reading in the interval -30min to -6min is always zero.
Any suggestions?
Not that I’m aware of - my graph appears to be fine http://www.jbest.net/weather/flash/index.html You could have a look in the clientraw.txt file and see if that’s the way the data is incoming from WD.
Julian
make sure you are using the latest version of weather display
Yes you need v 10.10q or later of WD for v1.04 of WDL
Julian
