BRIAN- Into http download when...
Into http download option, when the wd download a file and put it into folder download, rename the file with change of extension and not of name…
For example:
Download file called image.jpg >>> The WD put into download folder as image.jpg for the first time only.In the next downloads WD put into folder a file called image.jp1 , image.jpg2, image.jpg3 …
You can modify the routine to rename the file and not the extension?
Example:
Download file called image.jpg >>> The WD put into download folder as image.jpg for the first time. In the next download WD must to change in :
and next …
You have understand?
This is more than actual wd work…
Cheers Mario
i should have done it that way…
but the way it is at the moment is the way wd uses it to create the animation sequence…and so changing it will upset people using that sytem
(i.e view, downloaded images, then click on animate)
Ok, you should create an option to let the user select the extension of file downloaded.
Cheers
