Bray 1-wire Barometer
Does WD support the Bray 1-wire Barometer?
See ExpireSEO for details.
It looks like a nice design and there seems to be a lot of support from the hardware and software hackers for building and calibrating the unit.
yes
its a nice barometer
and you will find it works better in wd
you just need to know the volatage and baro hi/lo values (that should be supplied)
linctech,
I use that baro and it works perfectly. Jim Jennings built it for me and it has been brilliant ever since.
I use the older 1.1 version (as per your link) and it works flawlessly. There are newer versions, including one sold by hobby-boards.
It also provides temperature, so I use mine as the inside temp sensor.
Since I have had so much trouble with the AAG module I would like to order a kit or PCB from hobby boards but their web site says they have had some problems with the Bray barometer and so they are currently not selling it. :frowning:
maybe mail me your AAG barometer, and I will try it here?
but, though, as well, email me your settings file, wdisplay.ini, so i can try things are out here too
i am sure we can fix it
I just received my iLink adapter so I will give that a try to see if things get better. Also, now I have the 9097u free so I can use it to test the barometer using the AAG tools for an extended period of time. Will send the wdisplay.ini if nothing works out. Thanks!
