I just downloaded version 10.16b (beta) and when opening, the following message appeared: “WeatherD has generated erros and will be closed by Windows”. I tried to open it again, the result was the same. I downloaded the full version and there was no difference. Now, I’m working with version 9.97c, that I had by fortune in another folder, since downloading these new versions I overwriten the 10.16 I had before.
In my case, even rebooting doesn’t solve anything. Whenever I try to open WD, it just goes down. Just for helping Brian, I’m running Windows 2000 and my station is a Monitor II.
Good morning, Brian (it’s 8:00 in the morning, here…)
Well, I did what you asked me to, but the beta 10.16b didn’t work at all. But notice this: I installed 9.97c again, to be shure that I didn’t have enabled the pad out data or the logging extraction when the program starts. And it’s true, I didn’t have them ticked. But I did a little experiment: as I had the data logging ticked for 1 minute, as recommended, but never had clicked on “set”, I did it. I had a “generated errors” immediatly, but I started 9.97c again and everything runned ok. The strange thing is that I closed WD, opened PCLink and download data, and there was no data since the last update, about 0:00 AM. And now, the data logging was a 1 minute interval. But it is true that I find now, that all this time I had PClink logging in a 30 minutes basis (the data proves it), even if I had WD ticked for 1 minute interval. I don’t know if this is important or not, but the truth is everything was ok till version 10.16b.
By the way, I just tried 10.16c, and the problem remains, so I’m running 9.97c again.
While we try to figure out what this mistery is, is it possible for you or for someone to email me a 10.16 version, since I miss a lot of good things, lol?
its a commen thing that the data logging interval is set to only 30 minutes…also note that ticking 1 minute , you also need to click on set, and then you should see a success!
anyway, that does not look to be the problem
so instead it must be say a bad data file
as a test, exit wd
then rename the datafiles folder, and then start up wd…
also, as a tet, try the win95/nt versin, as its an older version, 10.12
I just did it, renamed to datafiles1, started WD again, and there was a new datafiles folder. Then, I installed 10.16c, but it crashed again, even with the new datafiles folder…
ok, its not the datafiles
it then must be something in the ini file
bring back the old datafiles
and then email me the file
wdisplay.ini
from c:\windows or c:\winnt
and also, wdisplayftp.reg from the folder databackup, after going action, back up registry now
and i will see if i can duplicate it here
also, try starting without being connected to the weather station
the other folder to try the rename trick is your webfiles folder (or where you have set your webfiles folder)
As Brian is trying to solve this problem concerning version 10.16c and WMII, I ask you the special favour of emailing me a 10.16 or 10.15 version, if someone has it.
Thank you for version 10.16, Gary. Brian is sleeping now, but tomorrow he will face this issue again. He has being doing some tests and I think is very close to undestand the problem. With your previous replies, he will have a lot more of information.
awake now
it looks like its an issue only affecting davis WMII, and using meteobrantes raw data, i have been able to also duplicate a crash, a divide by zero error
so i now need to find out why and what i changed!!!
and it was simply becuase i had the weather station setup not set the rain gauge type unless it was a davis station,so as not to confuse other station owners, but I only hooked it into the VP setup
so the rain gauge type was not set, and so it was set as zero by default, leading to a divide by zero
uploading 10.16d which fixes that bug, now
thanks!
I just downloaded version 10.16d and WD is working nice and smoothly. Brian, you are the creator of an excellent software, but you are also an excellent man. You care about the people who prefered WD. Thank you very much.
