BETA: WS2310 history retrieval: i need testers
In a new vers 9.79, ready now
go to setup, data logger setup, to enable
you can force it to get data from so many minutes ago, to test…
BUT
i would install this vers to a new directory
then create a file there called 2wd.txt
(make sure it is not 2wd.txt.txt, i.e untick hide known file extensions in the folder options under the folder tools)
and then let me know how the data looks (i am not sure if have wind speed and direction correct, as my station is set up in the room here,…(.
thanks!
Brian,
This is what I got on a win98SE machine:
WEATHERD caused an invalid page fault in
module at 0000:00000000.
Registers:
EAX=00000000 CS=0000 EIP=00000000 EFLGS=00000000
EBX=00000000 SS=0000 ESP=00000000 EBP=00000000
ECX=00000000 DS=0000 ESI=00000000 FS=0000
EDX=00000000 ES=0000 EDI=00000000 GS=0000
Bytes at CS:EIP:
BSOD after that and nothing in the 2wd.txt file. :?
John
Brian,
Just noticed I ran it in the existing WD directory by mistake. Made a mess and forgot all my settings. Reinstalled and all is well now. I will try the datalogger after dinner in a seperate directory as you suggested. :slight_smile:
John
the 2wd.txt file is just a flag file to tell WD to setup as brand now, (you will have to select the com port, weather station type all over again) so you data is not upset…and nothing gets logged to it, but the log files and graphs should get populated with the data from the ws2310
it is working for me, but I dont have a temp/hum sensor at the moment (someone borrowed it), and the anenometer is only sitting inside…
thanks!
thanks!
Same error message as before. I set the station type as soon as possible after startup then turned the logger on. It says “com port OK” at the top of the screen.
It appears to be doing something as the data light stays on constant (green) with the quality light (also green) but after about a minute I get the error messages. The error message repeats several times. No files were updated. except :
startuplog.txt
Weather Display starting, version 9.79
Form units created
Formws2000 created
Form extra sensor graph created
Formdailyhighlowpressure created
Formmetar created
Formtrend created
Formenergy created
Formnewsummary created
Formnewgraph created
Formlargedisplay created
Formtempdials created
Formhumdials created
Formbarodial created
Formrainlasthour created
Formalldials created
Formweatherdials created
Formsunmoon created
Formgraphform created
Formwmr918sensorlist created
Form sunmoonimages created
Form broadcast created, Final station type setting up…
The files “24hourrain.inf” and “direction.inf” also were created/updated within the 1st minute of startup. No other files were changed.
Win98SE
AMD XP1500
256 MB Ram
Only thing running in the background was Zonealarm standard edition.
Suggestions ?
John
i have made some improvements to this
please download and use a new 9.79 version
and let me know
thanks
We’re getting there. The latest 979 version started right up and started gathering the real time data. I’m using the wired version so that is updated every 8 seconds or so.
Turned on the datalogger and set to 30 minutes to retrieve. The gathering bar started filling as well as the % complete.
When I returned to the main screen, all real time values looked correct except outdoor temp which was 1.6F. I let it run another 5 minutes with no change. It’s a calm day so not much was changing on the display. The outdoor temp stayed at 1.6F.
I checked the real time graphs screen but it only had the 10 minutes I was up and running. The same for the graphs on the main screen. No histroy showing. The files in the log directory only showed the 10 minutes I was running, not the history.
The program error log has the following entries :
final_data[1]:=1;
final_data[2]:=16;
final_data[1]:=32;
final_data[2]:=48;
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=38;
final_data[4]:=60;
82 82 9A B2 EA 10 6C
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=0;
Formating history, # 1
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=39;
final_data[4]:=63;
82 82 9E BE EA 10 7F
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=0;
Formating history, # 2
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=41;
final_data[4]:=50;
82 82 A6 8A EA 10 92
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=0;
Formating history, # 3
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=42;
final_data[4]:=53;
82 82 AA 96 EA 10 A5
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=224;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=224;
Formating history, # 4
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=43;
final_data[1]:=48;
final_data[2]:=0;
Finished history data
final_data[1]:=0;
final_data[2]:=31;
final_data[3]:=35;
final_data[4]:=60;
82 BE 8E B2 EA 0F 3C
final_data[5]:=58;
final_data[6]:=247;
final_data[7]:=180;
final_data[8]:=118;
final_data[9]:=222;
final_data[10]:=109;
final_data[11]:=144;
final_data[12]:=244;
final_data[13]:=1;
final_data[14]:=0;
final_data[15]:=103;
final_data[16]:=88;
baro 998.6
out temp13.9
in temp24.3
in hum 45.0
out hum 90.0
rain 126.4
wind speed 0.1
wind dir 144.8
final_data[1]:=0;
final_data[2]:=31;
final_data[3]:=36;
final_data[4]:=63;
82 BE 92 BE EA 0F 4F
final_data[5]:=58;
final_data[6]:=246;
final_data[7]:=180;
final_data[8]:=182;
final_data[9]:=222;
final_data[13]:=1;
final_data[14]:=0;
final_data[15]:=119;
final_data[16]:=167;
baro 998.7
out temp13.9
in temp24.2
in hum 45.0
out hum 90.0
rain 126.4
wind speed 0.1
wind dir 167.3
final_data[1]:=0;
final_data[2]:=31;
final_data[1]:=32;
final_data[2]:=2;
final_data[1]:=0;
final_data[2]:=31;
final_data[3]:=38;
final_data[4]:=50;
82 BE 9A 8A EA 0F 62
final_data[5]:=58;
final_data[6]:=55;
final_data[7]:=212;
final_data[8]:=214;
final_data[9]:=109;
final_data[10]:=107;
final_data[11]:=135;
final_data[13]:=49;
final_data[14]:=0;
final_data[15]:=216;
final_data[16]:=61;
baro 998.7
out temp14.7
in temp24.3
in hum 44.0
out hum 87.0
rain 126.4
wind speed 4.9
wind dir 303.8
final_data[1]:=0;
final_data[2]:=31;
final_data[3]:=39;
final_data[4]:=53;
82 BE 9E 96 EA 0F 75
final_data[5]:=62;
final_data[6]:=29;
final_data[7]:=216;
final_data[8]:=134;
final_data[9]:=110;
final_data[11]:=132;
final_data[13]:=1;
final_data[14]:=0;
final_data[15]:=200;
final_data[16]:=254;
final_data[17]:=109;
final_data[18]:=248;
final_data[19]:=221;
final_data[20]:=213;
final_data[1]:=0;
final_data[2]:=31;
final_data[3]:=40;
final_data[4]:=56;
82 BE A2 A2 EA 0F 88
final_data[5]:=58;
final_data[6]:=236;
final_data[7]:=223;
final_data[8]:=134;
final_data[9]:=223;
final_data[13]:=1;
final_data[14]:=0;
final_data[15]:=70;
final_data[16]:=92;
baro 1000.3
out temp15.0
in temp24.0
in hum 45.0
out hum 84.0
rain 126.4
wind speed 0.1
wind dir 98.4
final_data[1]:=0;
final_data[2]:=31;
final_data[3]:=41;
final_data[4]:=59;
82 BE A6 AE EA 0F 9B
final_data[5]:=58;
final_data[6]:=116;
final_data[7]:=243;
final_data[8]:=38;
final_data[9]:=223;
final_data[11]:=130;
final_data[13]:=1;
final_data[14]:=0;
final_data[15]:=85;
final_data[16]:=165;
Formating history, # 5
baro 1000.2
out temp15.5
in temp24.0
in hum 45.0
out hum 82.0
rain 126.4
wind speed 0.1
wind dir 119.5
final_data[1]:=0;
final_data[2]:=2;
final_data[3]:=10;
final_data[4]:=30;
82 BE AA BA EA 0F AE
final_data[5]:=2;
final_data[1]:=0;
final_data[2]:=31;
final_data[3]:=44;
final_data[4]:=49;
82 BE B2 86 EA 0F C1
final_data[5]:=58;
final_data[6]:=206;
final_data[7]:=14;
final_data[8]:=7;
final_data[9]:=223;
final_data[11]:=119;
final_data[12]:=246;
final_data[13]:=1;
final_data[14]:=0;
final_data[15]:=214;
final_data[16]:=115;
Formating history, # 6
baro 1000.2
out temp16.2
in temp24.2
in hum 45.0
out hum 77.0
rain 127.4
wind speed 0.1
wind dir 300.9
final_data[1]:=2;
final_data[2]:=2;
final_data[1]:=0;
final_data[2]:=31;
final_data[3]:=45;
final_data[4]:=2;
82 BE B6 92 EA 0F D4
final_data[5]:=2;
final_data[1]:=0;
final_data[2]:=31;
final_data[3]:=46;
final_data[4]:=55;
82 BE BA 9E EA 0F E7
final_data[5]:=58;
final_data[6]:=157;
final_data[7]:=22;
final_data[8]:=183;
final_data[9]:=109;
final_data[13]:=1;
final_data[14]:=0;
final_data[16]:=136;
Formating history, # 7
baro 998.7
out temp16.4
in temp24.1
in hum 44.0
out hum 77.0
rain 127.4
wind speed 0.1
wind dir 303.8
final_data[1]:=0;
final_data[2]:=31;
final_data[3]:=47;
final_data[4]:=58;
82 BE BE AA EA 0F FA
final_data[5]:=58;
final_data[6]:=109;
final_data[7]:=30;
final_data[8]:=23;
final_data[9]:=222;
final_data[11]:=120;
final_data[13]:=1;
final_data[14]:=0;
final_data[15]:=217;
final_data[16]:=53;
Formating history, # 8
baro 998.6
out temp16.6
in temp24.1
in hum 45.0
out hum 78.0
rain 127.4
wind speed 0.1
wind dir 305.2
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=32;
final_data[4]:=61;
82 82 82 B6 EA 10 0D
final_data[5]:=58;
final_data[6]:=147;
final_data[7]:=52;
final_data[8]:=8;
final_data[9]:=64;
final_data[10]:=112;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=127;
Formating history, # 9
baro 1037.1
out temp23.7
in temp44.7
in hum 45.9
out hum 0.0
rain 0.0
wind speed 0.0
wind dir 0.0
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=34;
final_data[4]:=48;
82 82 8A 82 EA 10 20
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=80;
final_data[13]:=0;
final_data[14]:=136;
final_data[15]:=0;
final_data[16]:=216;
Formating history, # 10
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=35;
final_data[4]:=51;
82 82 8E 8E EA 10 33
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=0;
Formating history, # 11
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=36;
final_data[4]:=54;
82 82 92 9A EA 10 46
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=0;
Formating history, # 12
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=37;
final_data[4]:=57;
82 82 96 A6 EA 10 59
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=0;
Formating history, # 13
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=38;
final_data[4]:=60;
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=0;
Formating history, # 14
final_data[1]:=0;
final_data[2]:=16;
final_data[1]:=32;
final_data[2]:=48;
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=39;
final_data[4]:=63;
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=0;
Formating history, # 15
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=41;
final_data[4]:=50;
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=0;
Formating history, # 16
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=42;
final_data[4]:=53;
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[14]:=0;
final_data[15]:=0;
Formating history, # 17
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=43;
final_data[4]:=56;
82 82 AE A2 EA 10 B8
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=0;
Formating history, # 18
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=44;
final_data[4]:=59;
82 82 B2 AE EA 10 CB
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=0;
Formating history, # 19
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=45;
final_data[4]:=62;
82 82 B6 BA EA 10 DE
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=16;
final_data[16]:=16;
Formating history, # 20
final_data[1]:=0;
final_data[2]:=16;
final_data[3]:=47;
final_data[4]:=49;
82 82 BE 86 EA 10 F1
final_data[5]:=58;
final_data[6]:=241;
final_data[7]:=1;
final_data[8]:=2;
final_data[9]:=18;
final_data[11]:=16;
final_data[12]:=80;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=214;
Formating history, # 21
baro 1026.0
out temp-16.9
in temp26.9
in hum 45.9
out hum 10.0
rain 41.4
wind speed 0.0
wind dir 0.0
final_data[1]:=0;
final_data[2]:=17;
final_data[3]:=32;
final_data[4]:=52;
82 86 82 92 EA 11 04
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=0;
Formating history, # 22
final_data[1]:=0;
final_data[2]:=17;
final_data[3]:=33;
final_data[4]:=55;
82 86 86 9E EA 11 17
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=0;
Formating history, # 23
final_data[1]:=0;
final_data[2]:=17;
final_data[3]:=34;
final_data[4]:=58;
82 86 8A AA EA 11 2A
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=0;
Formating history, # 24
final_data[1]:=0;
final_data[2]:=17;
final_data[3]:=35;
final_data[4]:=61;
82 86 8E B6 EA 11 3D
final_data[5]:=58;
final_data[6]:=0;
final_data[7]:=0;
final_data[8]:=0;
final_data[9]:=0;
final_data[10]:=0;
final_data[11]:=0;
final_data[12]:=0;
final_data[13]:=0;
final_data[14]:=0;
final_data[15]:=0;
final_data[16]:=0;
Formating history, # 25
final_data[1]:=0;
final_data[2]:=17;
final_data[3]:=37;
final_data[1]:=48;
final_data[2]:=0;
Keep trying and thanks. Glad you had a couple of days away from WD. :slight_smile:
John
in the raw data, it shows the temperature in oC
i.e
baro 998.6
out temp13.9
in temp24.3
in hum 45.0
out hum 90.0
rain 126.4
wind speed 0.1
wind dir 144.8
is the windspeed correct at 0.1?
(knots), or should it be 1 knot?
and where it says formating data, but no raw data is displayed, then it didnt like what it saw,…
so, 10 minutes of the 30 minutes you requested was retrieved?
is the history interval set a 1 minute?
i have that working in wd now
i think i need to find the position of the last data record, and then work back from there, and then it will be good to go
oh and the info on how to do this was gathered by a group of very talented europeans…and i would like to thanks them
Brian,
Interval is set to 1 minute. It only recorded the real time data while I had WD running for about 10 minutes. It appears it didn’t collect any history. There wasn’t any wind at the time so .1 looks about right.
John
a new vers 9.79a, ready now, should be much better
its pretty darn good at this end!
i am just not sure if the windspeed is correct though
good news
after spending a wet day on this,and with a fan to blow the windspeed, and not that i have the temp/hum sensor back, i have it working very well now!
i have winspeed and direction perfected
i have the data position and wrap around perfected
i have it starting up OK
and i have added a start up check to the normal ws2310 routine too
version 9.79b
whew
its been a long road
but the rain gauge i have here is not working…so i cant test the rain
so i need help with that (i.e the raw data from view, program error log, after a data extraction that includes rain)
Brian,
Success !
It imported the history data correctly :). The graphs on the main WD display updated with the past 30 minutes and the daily log file looks correct.
However (you knew that was coming) the real time graphs updated the historical data as every 5 seconds instead of every 60 seconds. It recorded 12:15:20 then 12:15:25 then 12:15:30 ect. The data is all there it is just compressed into a couple of minutes according to the graph.
Again the main WD console charts look correct. It is just the real time graphs that have a glitch.
I’ll try the rain data after work today and send you the info you requested.
Nice going and thanks :slight_smile:
John
P.S. the latest file is still listed as 9.79a
good news!
i forgot to change the version number yet again…
real time grpah:
unfortnately i can not force in different times into that…
oops
i haved fixed a bug where the real time graph, and other things, would not update after getting the data extraction
uploading a new 9.79b now
I tried 979c while it was raining (1/8"+ per hour). I retrieved 30 minutes of data. All data loaded OK except the rain. No rain showed up on either the console graphs nor the real time graphs. However the program error log listed rain as a constant 54.9. I listed the 2 minutes of the error log file below.
baro 1057.9
out temp15.7
in temp25.4
in hum 45.9
out hum 89.0
rain 54.9
wind speed 0.0
wind dir 135.0
final_data[1]:=0;
final_data[1]:=16;
final_data[2]:=2;
final_data[1]:=0;
final_data[2]:=31;
final_data[3]:=46;
final_data[4]:=55;
final_data[5]:=58;
final_data[6]:=82;
final_data[7]:=251;
final_data[8]:=6;
final_data[9]:=77;
final_data[11]:=137;
final_data[12]:=106;
final_data[13]:=2;
final_data[14]:=0;
final_data[15]:=37;
final_data[16]:=42;
Formating history, # 26
baro 1057.9
out temp15.7
in temp25.4
in hum 45.9
out hum 89.0
rain 54.9
wind speed 0.0
wind dir 112.5
final_data[1]:=0;
final_data[2]:=31;
final_data[3]:=47;
Also the 2wd.txt file no longer resets the data. Data from yesterday as well as the correct com port and station type were correct at start-up.
John
ok
but i need all the raw data report so i can which raw data number is changing when it rains
thanks!
Excuse the newbie question but where is the raw data ? Is it one of the *.inf files in the data folder?
I searched this forum but didn’t find any reference to WS2310 raw data.
John
the raw data is what you posted here, from the view, program error log…I just need all that is in the log…thanks!
i,.e
baro 1057.9
out temp15.7
in temp25.4
in hum 45.9
out hum 89.0
rain 54.9
wind speed 0.0
wind dir 135.0
final_data[1]:=0;
final_data[1]:=16;
final_data[2]:=2;
final_data[1]:=0;
final_data[2]:=31;
final_data[3]:=46;
final_data[4]:=55;
final_data[5]:=58;
final_data[6]:=82;
final_data[7]:=251;
final_data[8]:=6;
final_data[9]:=77;
final_data[13]:=2;
final_data[14]:=0;
final_data[15]:=37;
final_data[16]:=42;
baro 1057.9
out temp15.7
in temp25.4
in hum 45.9
out hum 89.0
rain 54.9
wind speed 0.0
wind dir 112.5
final_data[1]:=0;
final_data[2]:=31;
final_data[3]:=47;
