Best way to run Weather Display Console
I want to run Weather Display Linux console version in the most practical way…
Should I run it in the background and automatically load when my Ubuntu Server starts…
I want it so if my power goes off…when it comes back on that my computer will automatically start and Weather Display will load and start logging again…I want a little interaction with it as possible.
Can someone please help me come up with the best way to run Weather Display and the how of doing it?
Give it a go and see how you like it.
Any hints on running a script in the background on startup?
What I did today 5 minutes before I left the house.
REM out the root check in GoWdconsole.sh. Do this at your own risk
#getUID() {
id $1 | sed -e ‘s/(.*$//’ -e ‘s/^uid=//’
Test if user is root and deny access if they are.
It is not a good idea to be running software as root.
#if [ “getUID” = 0 ] ; then
echo “ERROR: You can’t run this as ROOT. Change to another user and try again.”;
exit;
#fi
End of User test.
I then made a start up file.
/etc/run/weather.sh
#!/bin/bash
cd /home/change/consolewdfiles
./GoWdconsole.sh > /var/log/weather.log
exit
chmod 755 /etc/run/weather.sh
made a file called /var/log/weather.log
Add line to /etc/rc.local
/etc/run/weather.sh
It seems to work after reboot. I see underground weather is getting my updates…
ps aux | grep GoWdconsole
Good luck, David
Thanks for that.
My Weather Underground still doesn’t work…but I have set up a cronjob to do it and that works fine…it’s just not working when it calls it from consolewd
Is there a way to restart consolewd if there is a “send PC ready result -1” or some sort of alert?
I’ve had Weather Display work for a about two periods of 5 hours today…it just seems to stop after awhile…I’m running WRM100…I just want something robust and it seems WD console is not that robust? What am I missing?
Stephen
