Hi Brian
I have been having problem with main screen barometer graph, this happen at random times. I have rebooted pc, but does not help. The real time graph is ok? I have lined up times on screen shot. Using latest version, same with other versions. Any ideas??
it doesnt look real…but also, note, that the main screen baro scale is alot more exagerate than the real time graph baro scale…i.,e the real time graph, you will not bee seeing those jumps/spikes becuase of the lower barometer resolution
i guess i could add in where you can set the the lower/upper baro scale on the real time graph
the other thing:
the real time graph just plots the data at that point in time…
but the main screen graph, its an average of the last 10 minute data…i.e there must be some data blips…
i will need to work with you on preventing those, from the heathkit
email me direct about that
