Barometer blocked at the same value
I’ve a Oregon Scientific WMR918 weather station and the latest WDisplay installed. All work fine except the barometer value.
It’s always blocket at the same value 1013 hPa. The wStation display the correct value and I can see that it changes in the station, but the program read always the same value.
I’ve already setted up an offset of 61 as I’ve read in this forum but nothin’change.
What can I do?
You can see data and graphs on my site: www.meteoriccione.com
Marco,
Check Setup > Extra Settings/Misc setup/WD database setup
Then look down to the 7th checkbox (Show baro (metric) to .01 always) and see if this is checked. If it is then uncheck it.
that check wont do anything greg, its just to show to 0.1 or no decimal place, thats all :wink:
now, when you set the barometer offset (61 is just a starting point), make sure you click on set, then click on yes to save settings
BUT, also, make sure you have the correct weather station type selected…i suspect you need to select a WMR968 and not a WMR918
check that
Yes, it’s true.
I’ve choosed the 968 and all works fine, bah!
Thanx for your help.
