Good day!
I am running WD Live and I want to put on a background image but I want to put it so the dials and other data are overlaid on the page.
Good day!
there is a missing html command in the original wdl versions index.html file that you need to add
i.e
wmode=“transparent”
i,e
<EMBED src=“wdlv3_02.swf?mywebsite.com is available for purchase - Sedo.com” wmode=“transparent” quality=high bgcolor=#FFFFFF WIDTH=“100%” HEIGHT=“100%” NAME=“wdlv3_02.swf” ALIGN=“”
TYPE=“application/x-shockwave-flash” PLUGINSPAGE=“http://www.macromedia.com/go/getflashplayer”>
(but having that there makes firefox browser work harder)
The trick is to ensure that the WDL tags have the transparent parameter set, as Brians says, and secondly to either have the image you want as a background image to the page itself or as a background image for a table that contains WDL.
Julian
Where is that set Julain?
see my posting above
Hehe…I went thru the config file looking at each guage trying to figure out where the transparency setting was…doh!
Speaking of FF, do you know the trick to make it work? When I view my WDL page at home using FF v0.9.3 the entire screen is blue. When I go to work and use FF v1.0 the boarder around the WDL is blue, but all the WDL items are on a white screen. Does this have something to do with the transparency setting? I set the bgcolor in the index file::
Loma Rica NorCal Weather Live
Am I going about this the wrong way?
i have mine as below
is my flash what your aiming for link below
No, with FF 0.9.3 here’s what I see…I don’t want the white background around the dials and stuff…
Hmmm, just checked your site in MSIE and it looks like what I am trying to do…think I better upgrade FF and see if that helps.
Nope, must be a FF thing…
That will work for MSIE, but NOT for FF… For FF to work, you need to modify another part of the same html script like below:
<EMBED src="wdlv3_02.swf?http://www.mywebsite.com/wdlconfig.xml" wmode="transparent" quality=high bgcolor=#FFFFFF WIDTH="100%" HEIGHT="100%" NAME="wdlv3_02.swf" ALIGN=""
TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/go/getflashplayer">
Note that the transparent part is in the EMBED Statement. You should copy all of this and readjust your NAME tag again.
but having that extra wmode=“transparent” causes fire fox to be real sluggish with the WDL (its a FF thing)
Sometimes I can’t see the forest for the trees…missed that bgcolor in the embed statement… :oops:
Changing that made my screen look right to me here locally using FF 1.0.
Good Afternoon
Again, many thanks for the advice.
