Averages/Extremes Problem
An additional problem that I have had with both version 10.10 and now using 10.15b is that in View Panel/Averages/extremes, the last day of any month never is there. All days of the month are fine until you get to the last day of the month and nothing appears for that line of data.
Not a major problem, but it does make for extra work for me every time I am ending one month and starting a new month.
Arthur C
Woonsocket, Rhode Island USA
just checked mine, and july 31 is there
but, it will be to do with the daily reset bug introduced with your station type (please use the latest version to fix that), but , we can edit your logfile to make the last day show up (i.e it will be just that the day is changing too early in the logfile, or similar, i.e around the midnight time change)
email me your logfile, 72004lg.txt, and I will see about showing you how to edit/fix it
:slight_smile:
Thank you for the e-mail instructions. I added the extra lines to take log to midnight and now data for July 31 appears.
At the same time I went back and edited all files for January thru June in similar manner and now they all show data for the last day of the month as well.
Will I have to edit the logs each end of the month to correct this bug or do you plan to correct it with programming?
It really is not that much trouble if I have to do it myself, I am just happy that it resolves the problem of last day of the month not showing data.
Arthur C
Cumberland, Rhode Island USA
