yes
via view, aerages/extreme, scroll down, to see where to recreate the averages/extreme page
then set the month and year
then click on reset…
in 10.17p, it also now creates each day graph too
(you will need to upload those to your web site afterwards)
i spent alot of time on that becuase sopmeone wanted those graphs created, i tell that person, then i hear nothing back
gets disheartening when people jump up and down demaning things, then get impatient, and i work real hard on adding that, then i never here anything back, not even a thankyou
it wasnt actualy you i was having a dig at 8O
that i am nearly on top of the wish list,and the people with the crashes are getting sorted out, life is looking up
Hi Brian
using 10.17u i have just tried to redo september2004 but is failing to complete and no finish message is show even after 10 mins blue bar gets to 35% and only has upto 11th of month in file
if you close and reopen avg exteme it shows setpembers data at top and the month at bottom says 9 (not reset to october)
to correct i have to reset october but the file for this does not finish and when the file is viewed it has 13 days intead of 2 (15:00 on 3rd at time of post)
is this related to month changeover thead
Hi Brian
10.17w worked ok but while checking the graphs it produced i found i needed to convert log file to graphdata as they were blank took three goes.
still not getting 30th rain at bottom
Just tried to re-create September from version 10.17y and the only thing on the daily graphs after September 7th is Solar data. All the wind and temperature is missing.
