Auto uploading
Having spent a few hours getting to grips with the intricacies of FTP and HTML I now have the website accepting the various gifs. I had been uploading to Winderground AOK every 15 minutes as well. Now uploads only work if I am on line. The system appears to dial out OK but no data transfer happens. No doubt I have indavertantly altered a setting but I cannot see which one. Any help would be welcome. TIA.
post here what appears in the ftplogfull.txt file
or i.e under view, ftp error log, click on full log
list of files uploaded*
Starting to Dial Connection: AnyTime 13.03.2003
Modem change status, # 1
Initializing…
Modem change status, # 2
Modem change status, # 3
Modem change status, # 4
Modem change status, # 5
Modem change status, # 6
ERROR: The protocol is not configured. at time/date 17:15:31 17/11/2003 agenda item:
that looks like you will have to reboot your pc to get that one sorted out…
(i.e dial up networking sorted out)
and or try changing the modem change number in the connections setup, top box…to 6 maybe?
i.e can you connect normaly to the internet on that pc?
The connection and upload to Wunderground works perfectly except when WXD initiates the dialup i.e. when I am not online. Latest log follows
Initializing…
ERROR: The protocol is not configured. at time/date 22:15:31 17/11/2003 agenda item:
humm
try clicking on get ISP’s, and select the dial up networking you use, under connections
and, try seting the modem change number to 6, or , the default of 13
Now works set to 13. Thank you. All I need now is to sort out the website which I shall get assitance for from elsewhere.
