Auto scale
I give up and finally I took use customscreen. :wink: http://www.antto.net/saa/grafiikat.html
But when I add Auto scale graph in customscreen I notice so that graph is without x-axis value!
These two graphics are 7 day scale, but x-axis display “hour”!
Can these fix easily?
Eki
thats a good effor on the custom screen in wd, well done
you mean you are not now using the data feed to image salsa?
there was one thing left i had to do to get that right, but i was not sure which data field it was (maximum temperature?)
now, the auto scale graph…it should use the same settings as what you have in use in the auto scale graphs seciton of wd…
what do you have set there?
did you see that to resize things on the custom screen, hold down the ctrl key on the keyboard while moving the mouse over the object :slight_smile:
its good to see more people using the custom screens in wd
Thanks! :slight_smile:
I use ImageSalsa too, (it contains some options what I like use) but now as WD’s data2.csv fork fine I can drop VWS.
Did you mean; View > Autoscale graps.? There I’m select “7 days” Should I set that 7 days somewhere else?
Eki
