ASP Support
I want to upload wxlocal.html as an ASP file.
Can you change the programme to upload the file if it is called wxlocal.asp OR wxlocal.html
Gives greater flexibility in terms of scripting within an ASP page.
Is this type of scripting possible??
I want to add an asp header to the default page.
use the advanced internet file setup
under setup, customise the file creation/ftp schedule
there you can set the remote name for the wxlocal.html file
if you are running your own server, then you can use the special file conversion in the custom web page setup, under setup, ftp setup, to force a new file name (i.e yuou put in the local file name as anything but wxlocal.html, and set a new remote file name)
Greg
Have you tried this yet?
SteveD
No, I’m on vacation and away from home. I probably will not have time until after the new year.
Have just added this to the online help FAQ page.
Fred
