Hi Julian!
Do you think it would be possible to add a tag for the WD calculation of “Apparent Temperature” to WDL? I much prefer using that data over wind-chill & heat index.
i have added it the clientraw data in WD, so julian just needs to add it the WDL
(which is in the final stages)
see an example here:
http://weather.got-there.com/kazmesa12/wd/wd-live.html
I’ve now got Apparent temp available but where would you like it displayed? Optionally instead of main temperature, instead of heat index / humidex or as an additional instrument?
Julian
Julian,
Just have it available as an additional optional instrument to display, with its own set of tags/options, similar to the other temperature indexes.
Tom
Can someone suggest a concise phrase to describe Apparent temp for the tooltip?
Julian
