Just a question, In version 9.10, shouldn’t there be a “var” at the start of the uvImg section in the java script?
In Version 9.11, it’s back in front of uvImg but it’s missing in front of wrImg on line 355
// WIND ROSE: optional settings for the Wind Rose graphic
// tag: "ajaxwindiconwr"
// e.g. graphic name: "./ajax-images/wr-SSE.gif" or "./ajax-images/wr-nl-SSE.gif"
// .... grab the wind rose icons here: http://www.bashewa.com/downloads/bws-icons-wind.zip
wrImg =
{src : imgDir+"wr-{LANG}{DIR}.png" // where {DIR} will = wind dir (e.g. NNW), {LANG} = wrImg.lang
,width : 58 ,height: 58 ,hspace: 0 ,vspace: 0 ,border: 0
,style : ""
,align : "" // [ left | right | top | bottom | middle | texttop | absbottom | absmiddle ]
,lang : "" // with trailing dash (e.g. "nl-" will result in graphic name: "./ajax-images/wr-nl-SSE.gif")
,calm : "calm" // substitution for {DIR} (e.g "wr-calm.gif") ... specify "" if not to be shown or not available
,xlate : true // translate wind direction for icon names (multilingual system)
,useTag: "ajaxwindiconwr" // ajax tagname to use where the windrose icon should be placed
Also, in the UV code line 1951 you are making the uv reading an INTEGER always. With that, isn’t it impossible to then display 1.5 with the optional decimal point set at 1 in lines 491 and 508 of version 9.11 of ajaxWDwx.js and the settings file? Hope that makes some sense.
// UV Index
;;;set_ajax_obs('ajaxProgress',rand+'uv','in UV');
uv = parseInt(clientraw[79]);
set_ajax_obs("ajaxuv" ,uv.toFixed(dp.UV));
set_ajax_obs("ajaxuvNoD",uv.toFixed(0));
set_ajax_obs("gizmouv" ,uv.toFixed(dp.UV)) ;
var imperialDP = // decimal places
{ Temp:1 ,Wind:1 ,Baro:2 ,Rain:2 ,Snow:2 ,Alti:0 ,Dist:2 ,UV:0 };
Just to be clear, I haven’t been able to test version 9.11 yet as I’m at work and it may all work fine but as of this morning when I tested with 9.10 it was still a bit of an issue for me.
Would it be possible to rename ajaxdate@ on line 1634 to ajaxdate2 or something so that it does not casue a failure when validating the code? The @ symbol is not allowed to be used that way for the code to validate.
// current date and time of observation in clientraw.txt
set_ajax_obs("ajaxdatetime", WDdt.date(uom.dateFmt+' '+uom.timeFmt)); // 16/4/2009 02:37:07pm
set_ajax_obs("ajaxdate@" , WDdt.date(uom.dateFmt) + ' @ '); // 6/4/2009 @
set_ajax_obs("ajaxdate" , WDdt.date(uom.dateFmt)); // 16/4/2009
Scott
