Almost there
I am getting closer to the new web page.
With wdfulldata.xml I am not clear on how WD makes this. Could you run this by me again. I go to setup / control panel./ ftp internet .
then to custom web page/individual dials setup/ options
Check upload / produce xml. Turn the switch on., then OK.
Is that all or is there something else I should be doing. I don’t see the files either in WD or on the server.
I use setup, control panel, customize internet and it is at the bottom.
