AJAX Updating Problem
I am setting up the templates with Ajax. My main page, http://frankpinkston.com/weather/wx10.html is not updating. I have uploaded the two ajax javascript js files. Clientraw is in the same diorectory as http://frankpinkston.com/weather/wx10.html. How can I troubleshoot this?
Frank
The ajaxWDwx.js JavaScript is expecting the clientraw.txt file to be in the document root of the website…
Just change ajaxWDwx.js from
var clientrawFile = '/clientraw.txt'; // location of clientraw.txt relative to this page on website
to
var clientrawFile = '/weather/clientraw.txt'; // location of clientraw.txt relative to this page on website
and it should work fine :slight_smile:
Ken
I see that ktrue is the last to respond to this thread but I do not see the response he entered. Any help would be appreciated.
Ken
Thanks! That fixed the main page. I knew it was something simple.
However, the gizmo is not displaying data. The gizmo rotates from temp to humidity to depoint etc but no data is displayed. See http://frankpinkston.com/weather/wx13.html
Thanks for your help and the superb scripts
I see what you mean, Frank.
I think you need to make a couple of corrections to make it work on your home page and other pages in your site.
First, in c:\wdisplay\webfiles\wxlocal.html change the areas highlighted in red below to the contents of the code box shown below.
[color=red][/color] [color=red]
<!-- ##### end AJAX mods ##### -->
[/color]
<!-- ##### Note: AJAX mods are also included around many WD tags with data in clientraw.txt with -->
<!-- <span class="ajax" id="ajax..."></span> tags .. see page below for details                  -->
<title>Frank's Weather Station</title>
<meta name="Frank's Weather" content="Personal weather station." />
<meta http-equiv="content-type" content="application/xhtml+xml; charset=ISO-8859-1" />
<link rel="stylesheet" type="text/css" href="weather-screen.css" media="screen" title="screen" />
<link rel="stylesheet" type="text/css" href="weather-print.css" media="print" /></head>
<<body onLoad=“ajaxLoader(‘clientraw.txt’+new Date());”> >
to
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
   "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en-US">
  <head>
    <!-- ##### start AJAX mods ##### -->
    <script type="text/javascript" src="ajaxWDwx.js"></script>
    <!-- AJAX updates by Ken True - http://saratoga-weather.org/scripts-WD-AJAX.php 13-Dec-2006 -->
    <script type="text/javascript">
    useKnots = false; // set =true; to force use of knots as wind speed
    ajax_set_units('E'); // use 'E' for USA(english) units or 'M' for Metric
    </script>
<!-- ##### CHANGE  title to your site ##### -->
<!-- ##### CHANGE  description to your site ##### -->
  </head>
  <body>
Then change ajaxWDwx.js from
var ajaxLoaderInBody = true; // set to true if you have <body onload="ajaxLoader(..."
to
var ajaxLoaderInBody = false; // set to true if you have <body onload="ajaxLoader(..."
then the other pages in the site should perform correctly.
Ken
Thanks Ken That fixed the second problem. I appreciate your help. I wonder why your responses are marked as spam? You certainly are not a spammer !
I may bug you more. I seem to have an IE8 not always showing update “green”
Thanks again
Frank
On the ‘spammer’ front, I think Chris (administrator) has that straightened out by removing an anti-spam mod that was misbehaving :slight_smile:
IE8 is very sensitive to correct (valid) HTML … your wx10.html page still has extra tags in it (marked in red in the post above) … replace the top of your wxlocal10.html with the new top section and it should have IE8 performing correctly on that page.
Which other pages have the “IE8-not-showing-green” issue?
Ken
Ken,
Cleaning up the code as you suggested fixed the problem. I had the IE8 “compatibility mode” ON. With this - turned off it works fine. I still have the compatibility mode issue with the dashboard http://frankpinkston.com/weather/ajax-dashboard.php but I am making good progress. Thanks again for your generous help.
Frank
I am having an issue with the updating of ajax arrow for the Current Temperature after updating to IE8 (should have known better!).
It seems, as far as I can tell, that the only issue right now is the update arrow under the Current Temperature is not appearing on my index page. I am getting a small yellow box where the temp up or down should appear.
Webpage: www.carolinastormwatch.com/index.php
Any help would be appreciated as always!
Tom
I’m not seeing the yellow box you cited in either FF or IE8… I do see that the /ajax-images/falling.gif image returns
Not Found
The requested URL /ajax-images/falling.gif was not found on this server.
Upload falling.gif to the ajax-images/ directory to fix that.
Ken
Thanks Ken,
Never had a problem until I updated to IE8 though which is odd. The arrows all seemed to work I thought.
Will check it out to make sure they are there.
Many thanks!
Tom
Problem Solved!
For some reason I seem to be having this problem too. I used to not have an updating issue until just recently and I’m not sure if it is because of some changes I made and screwed something up or if a bug is introducing itself.
What I have noticed is that in IE8 the dashboard doesn’t update regularly unless I manually update by refreshing with F5 and I lost the green flash. The gizmo seems fine but the Dashboard is the issue. I’m hoping a fresh set of eyes might see what I am missing.
www.gigharborweather.com
Thanks in advance.
Brian
Just an update.
I have tried it with FF and seems to work but not with IE 8 and 7. I’m so frustrated. I have know idea what I did wrong.
Thanks again
Brian
I’m seeing ‘green flash’ updates on FF3.5, IE8, IE8(compatibility mode=IE7) just fine. The wind speed and update date/time are flashing green every 5 seconds.
Can you describe what you’re seeing in more detail… I can’t seem to reproduce your issue.
Ken
I found the problem with a Java script scrolling marquee that I inserted in both my index.php and wxindex.php.
I removed the code and everything seems fine now.
Thanks Ken for looking.
Sincerely
Brian
JavaScript is a tricky beast… one script error on the page, and all scripts on the page stop working (or don’t even start up). Firefox with FireBug extension is a good way to find JavaScript errors :slight_smile:
Ken
