Ajax Heat Color Word - 1.0 Final
I made a new feature for ajaxWDwx.js
This feature is called “Ajax Heat Color Word”
It makes the heatcolor word ajaxed with a color background that changes with the heatcolor, very similar to heatcolourword in WD
See it being used on my ajax dashboard here:
http://www.proweatherstore.com/weather/index.php
To see how it progressed from BETA to Final, see this post.
http://discourse.weather-watch.com/t/32531
This is version 1.00 Final
Here is how to add it:
edit ajax-dashboard.php:
change:
<?php  echo $heatcolourword; ?>
to:
<span class="ajax" id="ajaxheatcolorword"><?php  echo $heatcolourword; ?></span>
edit ajaxWDwx.js:
change:
// -- end of language settings ----------------------------------------------------------
to:
var langHeatWords = new Array (
 'Unknown', 'Extreme Heat Danger', 'Heat Danger', 'Extreme Heat Caution', 'Extremely Hot', 'Uncomfortably Hot',
 'Hot', 'Warm', 'Comfortable', 'Cool', 'Cold', 'Uncomfortably Cold', 'Very Cold', 'Extreme Cold' );
change:
// Mike Challis' counter function (adapted by Ken True)
to:
// function to add colored heatColorWord by Mike Challis
// final version 1.00
function heatColor(temp,WindChill,Humidex) {
  var hcWord = langHeatWords[0];
 if (temp > 32 && Humidex > 29) {
  if (Humidex > 54) { return ('<span style="border: solid 1px; color: white; background-color: #BA1928;">&nbsp;'+langHeatWords[1]+'&nbsp;</span>'); }
  if (Humidex > 45) { return ('<span style="border: solid 1px; color: white; background-color: #E02538;">&nbsp;'+langHeatWords[2]+'&nbsp;</span>'); }
  if (Humidex > 39) { return ('<span style="border: solid 1px; color: black; background-color: #E178A1;">&nbsp;'+langHeatWords[4]+'&nbsp;</span>'); }
  if (Humidex > 29) { return ('<span style="border: solid 1px; color: white; background-color: #CC6633;">&nbsp;'+langHeatWords[6]+'&nbsp;</span>'); }
 } else if (WindChill < 16 ) {
  if (WindChill < -18) { return ('<span style="border: solid 1px; color: black; background-color: #91ACFF;">&nbsp;'+langHeatWords[13]+'&nbsp;</span>'); }
  if (WindChill < -9)  { return ('<span style="border: solid 1px; color: white; background-color: #806AF9;">&nbsp;'+langHeatWords[12]+'&nbsp;</span>'); }
  if (WindChill < -1)  { return ('<span style="border: solid 1px; color: white; background-color: #3366FF;">&nbsp;'+langHeatWords[11]+'&nbsp;</span>'); }
  if (WindChill < 8)   { return ('<span style="border: solid 1px; color: white; background-color: #6699FF;">&nbsp;'+langHeatWords[10]+'&nbsp;</span>'); }
  if (WindChill < 16)  { return ('<span style="border: solid 1px; color: black; background-color: #89B2EA;">&nbsp;'+langHeatWords[9]+'&nbsp;</span>'); }
 }  else if (WindChill >= 16 && temp <= 32) {
  if (temp < 26) { return ('<span style="border: solid 1px; color: black; background-color: #C6EF8C;">&nbsp;'+langHeatWords[8]+'&nbsp;</span>'); }
  if (temp <= 32) { return ('<span style="border: solid 1px; color: black; background-color: #CC9933;">&nbsp;'+langHeatWords[7]+'&nbsp;</span>'); }
  return hcWord;
change:
set_ajax_obs("ajaxfeelslike",feelslike + uomTemp);
to:
                // # mike challis added heatColorWord feature
                var heatColorWord = heatColor(clientraw[4],clientraw[44],clientraw[45]);
                set_ajax_obs("ajaxheatcolorword",heatColorWord);
Thanks for this nice add-on, really appreciated!
Mario
Nice work Mike. Have it incorporated with no problems. Mike one quick question. To change the range of temps I can just go to the ajaxWDwx.js and edit those settings? My temp range is different due to the fact the area I live in. Colder than avg temps.
Chuck
Yes you can do that, keep in mind that they are celsius regardless of what your site displays.
Yes I am aware of it being Celsius Mike. Thanks for the reminder. I will get to it a little later. Spending time with the spouse.
Chuck
Thanks Mike!
It works fine! It’s easy to adjust the temperature criteria according to the weather conditions on your region! :smiley:
Thanos
Hi Mike
Thank you very much for this new feature in the ajaxWXwd - I have it up and running on my website without any problems. Very easy with your excellent description.
Henrik
Thanks Mike. Works like a charm
Hello Mike:
I’m using the latest beta version…did you make any additional changes from the last beta version to the current version? Just checking to see if I need to make any changes…
Ronnie
Yes I think I did.
Thanks Mike…I will make the necessary changes…
Ronnie
Will the changes be incorporated into the “master” set?
Mark
Yes, Ken said he would add them in.
All done… V1.28 of Canada, USA, World templates released.
12-May-2008 ajaxWDwx.js and ajax-dashboard.php with HeatColorWord mod(MChallis), plaintext-parser.php V1.10 fix → arrow (Canada, USA, World)
Thanks Ken :smiley:
It’s very strange, I’ve added/replaced all the text as described, but still only the “normal” text is showing (without the border and colour).
Anyone got any tips?
I also don’t have a footer when you watch the index.php file for some reason… :frowning: Don’t know why, it should be there.
Click my banner for link
The ajaxWDwx.js script appears correct, as does the markup for id=“ajaxheatcolorword” in ajax-dashboard.php
The ajaxWDwx.js script isn’t running however, possibly due to another JavaScript on the page having an error (one failure, and all JavaScript on the page stops running until the page is reloaded).
For the lack of a footer, it appears that your index.php ends with
<div align="center">
        <p><a href="http://www.paulen.no/topsites/"><img src="http://www.paulen.no/topsites/button.php?u=NorwegianMartin" alt="Paulen Top 100 Weatherstation List" border="0" /></a></p>
      </div>
      </p></table></tr>
… maybe there’s a PHP error on the page below that or you’ve included a script that is exiting instead of returning ???
Send me a zipped copy of your index.php and I’ll have a look.
Ken
I have seen this problem before. You have enabled the ajax gizmo on the index page, you cannot do that because it conflicts with the ajax dashboard.
You are probably actually getting a PHP error, but your PHP is not showing it (sometimes PHP is configured that way)
This is probably the error if it would show …
Fatal error: Cannot redeclare gen_difference() (previously declared in ajax-gizmo.php:131) in ajax-dashboard.php on line 692
Edit your index.php and set the gizmo to false
$showGizmo = false; // set to false to exclude the gizmo
Maybe Ken should remove the $showGizmo setting in the wxindex.php, because I have seen this happen before when users configure it from false to true
