Advice on solar setup please
What is the best way to set up for the solar sensor
1st Question
Should I adjust the temp reading for 100% at mid day in full sun so it just reads 100% and therefore what happens latter in the year when the temperature difference is a lot less or do I set for 100% when there is full sun hitting the sensor but is not fully above.
As the jar has only a black bottom the angle of the sun seems to make a difference.
2nd Question
what is the
you most likely will need to tweak it as the year changes
the tenth is for a fine tune…
Can anyone answer my first question??
Check out Leo’s post in this recent thread http://www.weather-watch.com/smf/index.php?topic=4503.0
1st Question
As the jar has only a black bottom the angle of the sun seems to make a difference. …Brian
I started with a temperature setting of 17C. I set my solar sensor in a jar temperature for 100% by tweaking the temperature setting at solar noon on a clear day. [June 21 is a good day if it is clear.] This took me about three months. Then I leave the setting alone. Occasionally I will verify the setting. Usually I do not have to adjust the temperature setting as the year changes.
My current setting may be viewed at: http://littleswitzerlandweather.info/img/Solar%20Setup0818B4.gif
