maybe
but it is for the more advanced users, hence why its in the advanced setup
Brian
some new feedback. My MQTT server became unavailable earlier in the day. Later this evening I started the Task Manager on the machine running WD and noticed that there were hundreds of cronwdmqtt.exe processes running!
Are you starting a new process every time? Also, you may want to consider adding exception handling logic.
Renato
i do have exception handling logic in place
the program should be closing after the data is sent
(and yes then a new one is spawned)
but what I could do is add a time out → close
try this update
http://www.weather-display.com/downloadfiles/cronwdmqtt.zip
Brian
would it make more sense to have the connection only be established at startup and leave it connected?
For example, I have built about a dozen IOT devices using ESP8266 which publish to an MQTT server every sec. I establish a connection as the ESP boots up. The only time I re-estaglish the connection is if the connection dies (i.e. wifi becomes unavailable, mqtt pod crashes etc) at which point, I try to reconnect every 5 mins.
I am not trying to tell you how to code, just a suggestion.
Renato
i was not really envisaging people wanting to send data frequently, that was all
otherwise yes I would do it that way, and still could yet
anyway , make sure to use this new update and see how that goes
Brian
I tried the new program, but it does not publish any messages. I replaced the new one with n-1 and messages started showing up.
Renato
my bad
try again
once this runs stable then can work on having it stay logged in and running
Yep, that did it.
Tomorrow morning (my time) I am going to simulate MQTT going offline and will keep an eye on the total number of mqtt processes.
Thanks again
Renato
actually download yet again
as I need to have added a time out
because if no connection then it will not close
Brian
I have downloaded the latest one.
I shut down the pod that MQTT is running in. Immediately, I noticed that WD started 3 new cronwdmqtt processes. Then a forth one started but shorty after was terminated. The creation/termination of a new process kept on going leaving at anytime 3-4 of these processes.
Renato
yeah, that is because the time out is set to 10 seconds
I will now work on leaving it running…if say the frequency to send is less than the default of 60 seconds say?
Do you expect the overhead to be significant if you just left it always connected?
Here is another idea…
What if you were to look at the overall app as a collection of “microservices” where the functionality of the main code would be to generate and publishing the data (clientraw). Then each other microservice (i.e. wu upload, mysql upload, ftp etc) would be its own microservice that would subscribe to the message and “take it from there”.
The advantage of this would be
- gain granularity of control as to when each process runs
- distribute the microservices across multiple os/hw.
- facilitate the creation of “3rd party” plugins
Renato
MQTT is a lightweight protocol so should be no overhead and the data sent is not large either
re 2, yes, it does open up lots of possibilities
including getting data to a client version of WD running or the WDliveapp or similar
use a new .zip update
which also has a new cronwdmqtt.exe version (vers 1.4) as well as a new weatherdisplay.exe version
now if you have the update rate less than 60 seconds (default)
then the cronwdmqtt.exe will not exit but keep on running (you can click on the icon to see whats its doing etc in the system tray) and will send the data at the update rate
I have tested and its working
Brian
deployed the new version. Everything working.
Let me know if you would like to brainstorm around the microservices…
Thanks again
Renato.
there is now the opportunity for other software developers to use the MQTT message data to add on services?
Brian
Here is an example of the “art of possible”. Using node-red to subscribe to the message and generate a dashboard.
Renato
kewl
I thought there might be a way to drive a live web site , yes?
so no ftp need to get your data there
Brian
I guess node-red could be used for creating a more detailed webpage. That would indeed eliminate the need for ftp/sftp.
I planning to reach out to one of my colleague at work tomorrow who is the “expert” on node-red.
Meanwhile, if you wish to play with it, you can install NR on a footprint as small as a RPi.
[{"id":"e959a54f.7adff8","type":"ui_gauge","z":"3184c35f.9c6f6c","name":"","group":"d702a2bb.6772d","order":5,"width":"8","height":"8","gtype":"gage","title":"Outside Hum","label":"%","format":"{{value}} %","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1101,"y":514,"wires":[]},{"id":"d702a2bb.6772d","type":"ui_group","z":"","name":"Weather Display - Southampton","tab":"eb9cf7e0.fcf888","order":1,"disp":true,"width":"28","collapse":false},{"id":"eb9cf7e0.fcf888","type":"ui_tab","name":"Tab 1","icon":"dashboard","order":1}]
One more question/asl, not trying to be a pig
How difficult would it be to give the option to publish either clientraw or customclientraw.txt. The latter already being in JSON format would lend itself better for loading the data into a database, specifically InfluxDB.
Renato
