I can’t figure out why the program that AAG write called Weather english V5 and Weather Display show two compleatly different things.
With the Weather English program the devices all come up correctly and WD tends to throw everything up 4 or 5 times each. Below are two pictures that show you the difference in the programs taken one after the other with no change to the physical setup.
The barometer is connected to the HUB with a CAT5 cable so it can use the power from the HUB.
The rain gauge is not showing up in WD nor is it being allocated, but the Weather Eglish V5 is picking up the device fine.
