A small problem here
Hi again
Each time - when I open the Control Panel → FTP-Setup - I have to go to the client/server menu also to deactivate the solar option - looks like that the solar option is always “on” as a default value.
What I mean - for example - I go in the FTP-Setup and then to connections - before I leave the connections setup with “ok” - I have to go - always - here - to deactivate the solar option.
Therefore - that I have the WM918 Weatherstation and I do not have or better I can’t use a solar-sensor - I do not need that option.
If it will be possible - is there a way that this option save the value I give him? Or is there a reason - always after entering the FTP-Setup Menu - that the default option is “on”?
Thx if it will possible to make this little change…
ah, it was a bug…in the code…i was missing a space in the updating of the registry entry
uploading a fix now
I will let you know when its ready to download
try the latest beta version
should be OK now
also, the GPS settings should be remember now too (reset them again though)
Hello Brian
WOW - you are fast! Thx for fixing the Client-Server Solar problem - now it is like it should - Thx again!
About the GPS-Setup - please have a look at the GPS-Posting - somehow it isn’t working correctly - maybe you can have again a look - Thank you!
Stephan
